IV diagnostics regressor endogeneity
k100z
Postby k100z » Tue Aug 06, 2013 6:50 pm
After running an instrumental variable estimation for cross sections, one can check for the endogeneity of the regressors: View / IV Diagnostics & Tests / Regressor Endogeneity Test
It works fine when running a GMM estimation, but there are no results for the TSLS. According to the handbook it should be available for GMM and TSLS. It is executing the test, but test statistics are simply not displayed. the are no numbers for
Value df Probability
___________________
Re: IV diagnostics regressor endogeneity
Postby EViews Gareth » Tue Aug 06, 2013 7:38 pm
Could you provide your workfile, along with EViews version and build date (available from Help->About EViews).
k100z
Postby k100z » Wed Aug 07, 2013 12:12 pm
Eviews 8, Aug 1 2013build, workfile attched.
2001_test.wf1
(181.6 KiB) Downloaded 448 times
Postby EViews Gareth » Wed Aug 07, 2013 12:56 pm
Thanks.
k100z
Postby k100z » Tue Sep 03, 2013 12:44 pm
Hi Gareth,
did you find any solution/explanation to my problem?
Postby EViews Gareth » Tue Sep 03, 2013 12:49 pm
I believe it is fixed in the latest patch.
Postby EViews Gareth » Tue Sep 03, 2013 12:53 pm
Hmmm, I just checked the latest patch, and actually it isn't fixed.
We will investigate.
Of course, in the mean time, you can always calculate the statistic manually - the secondary estimation output is shown, you just need to find the difference between the original J statistic and the secondary estimation's.
