I have read the detailed guide of how to import data on an other topic but cannot the import the attached file into Eviews 7. Could someone please help me out here.
Importing World Bank Panel Data
- Inflation version 2.xlsx
- (105.41 KiB) Downloaded 1069 times
Re: Importing World Bank Panel Data
Probably the easiest thing to do, if you're using EViews 7 rather than 8, is to transpose it manually in Excel, then put it into EViews.
I tried that first. But since its a panel data of 190 countries, I have to copy and transpose paste for every country one-by-one.
Is it still the easiest way possible?
If it were me, I'd just upgrade to EViews 8
will the beta version do?
the process in EVIEWS 8 BETA is straight forward?
The Beta version will no longer work.
But, if you do get EViews, this code will make both a pooled page and a panel page:
wfopen(page=pool) "inflation version 2.xlsx" byrow colhead=2 namepos=last @rename country_code year
pagestruct @date(year)
%cxlist = @wlookup("???", "series")
pagestack(page=panel) {%cxlist}
rename var02 inflation
Thank you Gareth. :)
Also, I found Tableau add-in for excel to do the trick of reshaping this wide data into long which can be easily imported into eviews.
