Stepwise Least Squares ->Lag specification
andre182
Postby andre182 » Fri May 14, 2010 10:22 am
I would like to know how to specify lags when doing the stepwise least squares method. I intend to run a backward stepwise least squares from a general to a specific model à la Hendry. I do not want to write down every single lagged independent variable into the "List of search regressors"-window. Is there a special way to include all lags(maximum possible number of lags) that the programme should stepwisely analyze like for instance inflation(-x) or inflation(-all) or inflation(-all lags) etc? Thank you very much in advance. Greetings
Re: Stepwise Least Squares ->Lag specification
Postby EViews Gareth » Fri May 14, 2010 10:31 am
inflation(-1 to -5)
will include all lags of inflation between 1 and 5
andre182
Postby andre182 » Tue May 18, 2010 5:36 am
Thank you Gareth!
Now, I have encountered another problem-After clicking the OK-button to run the Stepwise Regression, EViews shows a failure message saying: "Positive or non-negative argument to function expected". What does this mean? The options that I have chosen are backwards, unidirectional with p-value of 0.05, 1000 backward steps, no number of regressors to select and no weight series. Thanks a lot. Regards
Postby EViews Gareth » Tue May 18, 2010 8:18 am
Hard to say without having your workfile.
j52
Postby j52 » Thu Aug 01, 2013 1:37 am
Hey Gareth,
is it possible to specify the lags for a differenced value? e.g. d(inflation(-1 to -5)) Because then I get an error message.
Postby EViews Gareth » Thu Aug 01, 2013 6:49 am
No.
CharlieEVIEWS
Postby CharlieEVIEWS » Sat Aug 10, 2013 8:11 am
If im not mistaken, and if you haven't already found a simple solution to your problem, I believe you could use:
genr dinflation = inflation-inflation(-1),
then you can use:
dinflation(-1 to -5)
