Forecast evaluation
j52
Forecast evaluation
Postby j52 » Mon Jul 29, 2013 11:07 am
is there an option to generate a forecast evaluation of two imported series, e.g. to compare the actual generated forecast (w/o using eviews) of a company to the actual sales?
Thanks a lot.
Re: Forecast evaluation
Postby EViews Gareth » Mon Jul 29, 2013 11:54 am
Which forecast evaluation would you like to perform?
j52
Postby j52 » Wed Jul 31, 2013 7:26 am
Root Mean Square Error, Mean Absolute Error, Mean Abs. Percent Error, Theil Inequality Coefficient.
Postby EViews Gareth » Wed Jul 31, 2013 7:53 am
@rmse(y,yf) @mae(y,yf) @mape(y,yf) @theil(y,yf)
j52
Postby j52 » Wed Jul 31, 2013 9:51 am
Awesome, thanks a lot!
j52
Postby j52 » Wed Jul 31, 2013 10:15 am
Might be a stupid question, buT how do I show the value? Do I have to create a series: series RMSE=@RMSE(d,df)? Or is there a faster way to show the one or even all of the evaluations at once? And what the command for the Theil's Bias, Variance and Covariance Proportion? Thanks a lot.
Postby EViews Gareth » Wed Jul 31, 2013 10:26 am
Just type:
=@rmse(y,yf)
There is no command for the components.
Nicole
Postby Nicole » Wed Jul 30, 2014 7:53 am
I am using Eviews 8. When I try to calculate the RMSE and MAE for my forecasts using the @mae(return,returnf) and @rmse(return,returnf), but I keep getting the same number for both measurement errors. How can this be? Am I typing it incorrectly? :?
Postby EViews Gareth » Wed Jul 30, 2014 8:11 am
create u 10 series return=nrnd series returnf=nrnd scalar rmse = @rmse(return, returnf) scalar mae = @mae(return, returnf) show rmse show mae
Run that a few times, you should get different numbers each time.
