I am using Eviews 7.2.
After estimating a VAR and setting the identifying restrictions, how can I retrieve the resulting structural innovations/shocks to use them for further analysis?
Retrieve structural shocks from SVAR
aleconomista
Re: Retrieve structural shocks from SVAR
Hi!!
You have two options...eventhough with some extra calculus....: 1) get the inverse process using the matrix A and B that appears at the end of the structural factorization (Eviews report), 2) using the coeficcients of the structural factorization and the residual estimates in order to find the shocks in a recursively way....eventhough you will estimate structural shock adjusted (it's not so good)
The best calculus for a three variable model is (scheme 1):
matrix B=e(B)
residual e1
residual e2
residual e3
A matrix contains e1 e2 e3: matrix(e)
matrix of structural chocks=(inv(B)*e')'
See how to programate in Eviews.
I hope that these can help you.
matrix B=e(B)
residual e1
residual e2
residual e3
You can use HDecomp add-in. Read the help file inside the folder for instructions...
