There is a way to filter objects (like "object filter option") in workifle using code?
help, filtering a workfile using code.
Re: help, filtering a workfile using code.
To what end?
Hi Gareth,
To show only a few specific objects (for example, an equation object named "myecuacion") in workfile. While the rest of the objects in the workfile (series, groups, etc) is hidden. I do it for the people who use the workfile not distracted seeing the details and focus only on the object equation, what is the important one. I want to do this with code.
Thanks.
Thanks.
Unfortunately not :(
Ok, thank you. If I filter objects in a workfile and then save and close it, when I open again this workfile appear again all objects. Have you considered in the future enable an option to save also the filters?
Thanks again.
Thanks again.
We'll certainly consider it.
