syntax highlighting
Line numbering
Highlight the current parenthesis level when editing (useful when nested).
Highlight the current line
Collapse blocks, such as IF, FOR, WHILE or subroutines blocks
the configure file
some screen shot
Collapse blocks
The screen short are from notepad++ 6.2.2, http://download.tuxfamily.org/notepadpl ... imalist.7z
Or you can find one custom-made by me: http://forums.eviews.com/viewtopic.php?f=5&t=7098
one issue to resolve: see the line 36 or 38, the number is part of the name of variable, but highlight as a number
notepad++ syntax highlingting for EViews
Re: notepad++ syntax highlingting for EViews
there is one annoying bug: identify the " if condition" as "if block"
- screenshot
- cond if.png (31.42 KiB) Viewed 33613 times
The semisolution would be to define closing "Folding in comment" keyword, see
https://sourceforge.net/p/notepad-plus/ ... /56132212/
One potential solution would be to have "then" be the trigger word for if statements rather than "if".
thanks, great!One potential solution would be to have "then" be the trigger word for if statements rather than "if".
update to npp 6.4.5, and for EViews 8.
you can import the language definition file and keep your npp version
for full working package (npp.6.4.5.bin.minimalist.7z and add some plugins, see http://forums.eviews.com/viewtopic.php?f=5&t=7098)
upzip the attachment, and double click the notepad++.exe will do. custom shortcuts
F1: insert time stamp (yyyy-mm-dd hh:mm)
F6: run current file (C:\EViews8\EViews8.exe" in shortcuts.xml should be changed according to your installation of EViews)
F9: save (if change) and run current file
minor update:
1 notepad++ to ver 6.5
2 add few keywords for syntax highlingting
if your old version works, you are safe to ignore this update.
dagfinnrime
- Contact:
thanks for making this available.
I already have NotePad++ installed for other purposes. Which files do I need to take from your "full" setup in order to make it similar?
Solution?
Just copy into my existing notepad++-folder and keep any files with same name?
Dagfinn
Solution?
Dagfinn
Maybe you can try
1 extract http://forums.eviews.com/download/file.php?id=2113 and run the notepad++.exe (close all your running np++ first)
2 export the language definition of EViews as EV.xml
3 exit the notepad++, and launch your original notepate++, import the EViews language
4 copy the RunMeU.dll and NppTimestamp.dll to plugins sub-dir of your original np++
Good luck!
PS: I remember that the background color of np++ is global, you can adjust the color scheme.
Good luck!
For EViews 9
import the language definition file, and keep your npp version
if your old version works, you are safe to ignore this update (just import the language definition file, and delete your EViews 8 language definition in np++ ).
A very nice try!
1. Could you update the notepad++ version for EViews 10 and 11?
2. I am wondering: can I run the EViews code in the notepad directly?
Thanks a lot!
Thanks a lot!
