Panel data: sample selection, cross section and period
When working with panel data, how can I select from the whole sample just a few cross sections and a few periods?
I tried to use the Quick/Estimate Equation/Estimation Settings/Sample box but, apparently it only allows selection of periods, not of periods and cross sections simultaneously.
Re: Panel data: sample selection, cross section and period
Use a sample condition with an "IF" for the cross-sections.
Thanks for your reply. However, I noticed you had replied only today, 27-July-2013. Reason for this is that your answer is in Technical Support/Estimation whereas I had posted my query in Econometric Discussions. I was expecting an answer in Econometric Discussions, not in Estimation. Actually, I had been sort of taken aback as my query had disappeared from Econometric Discussions. I found your answer in Estimation by struck of luck. How did my query get moved from Econometric Discussions to Estimation?
I can well realize that now. Problem is I didn't know that happened.
I would have have the exact same question and just can't find an answer. Is there somewhere an answer?
Best
YK
Best
YK
Other than the answer given in this thread?
at first, i cannot find this option in the estimation window.
secondly, in the sample window, it doesnt work to just put the country code ("aus" is not defined)
thirdly, there must be a simple code to choose certain countries (= cross sections). i havent figured that one out.
best
YK
best
YK
Use an if condition.
unfortunately, I am not even aware of the basics. the @crossid doesn't want to work.
how does it look like, if i want to run the regression
equation uncon_beta.ls dlog(ypc) log(ypc) c
for 28 eu countries (aut, bel, etc.)
is it
and follow up question:
i also would like to create a series with the averages of gdp from each country like
btw. i do not have a sheet with single countries. just the panel sheet.
best
YK
is it
if @crossid=aut bel dnk
equation uncon_beta.ls dlog(ypc) log(ypc) c i also would like to create a series with the averages of gdp from each country like
series average_gdp = @mean(gdp 'here i need to tell him: from each crossid best
YK
smpl if country="aut" or country="bel" or country="dnk"
You can use @meansby
the @meansby doesnt work. it gives me a weird list, where in the @crossid column, there are means I dont understand like [0,50] and [50,100]. these are definily not the means i am looking for.
isn't there a quick code for it?
best
YK
best
YK
Did you use the @meansby function?
i use the @meansby function (but by following the clicking instructions of the eviews help)
is there a code for it?
something like this?
series gdp_average = @meansby(gdp).@crossid -
series gdp_average = @meansby(gdp, @crossid)
