Seasonal adjustment: EViews' specification file?
apple
Postby apple » Fri May 24, 2013 7:07 pm
When we request X12 seasonal adjustment from EViews, Eviews will write out a specification file. Could anyone kindly tell me where I can find and how I can open such a file?
Re: Seasonal adjustment: EViews' specification file?
Postby EViews Gareth » Fri May 24, 2013 10:44 pm
Which version of EViews?
apple
Postby apple » Sat May 25, 2013 5:21 pm
I am using EViews 6 but can access to new versions if needed. Thanks.
Postby EViews Gareth » Sun May 26, 2013 12:46 pm
It will be located in your EViews temporary directory. You can find the location from the Options->File Locations entry.
Moody_Irish
Postby Moody_Irish » Mon May 27, 2013 11:19 am
I'm writing code to seasonally adjust panel data by restricting my sample to each individual cross section. As the cross section identifiers are not continuous, I'm looking for a compact way to iterate over a discontinuous variable. Any suggestions?
Cheers!
Postby EViews Glenn » Tue May 28, 2013 9:29 am
EViews 8 has the @uniquevals function which will return the vector or svector of unique values. You can then loop over sample exclusions using those values.
