Permanent-transitory decomposition
SeaWill
Postby SeaWill » Fri May 03, 2013 3:11 pm
I've estimated a VECM and would like to do a Gonzalo Granger's (GG) decomposition to extract the permanent component of my dependent variable. Does anybody have the programming code....i will setle for the BN decomposition if GG is not possible in eviews.
trubador
Did you use forum search?
Re: Permanent-transitory decomposition
Postby trubador » Mon May 06, 2013 12:06 am
If you decide to proceed with Beveridge-Nelson decomposition, then you can download an EViews add-in from here: http://forums.eviews.com/viewtopic.php?f=23&t=4531
SeaWill
Postby SeaWill » Tue May 14, 2013 9:35 am
Appreciate the feedback. So i'm using Eviews7. I tried to download the add-in but its returning an 'invalid thread' message. Is it because my eviews is too old...if so do you have a b-n decomp add-in for Eviews7 :?:
SeaWill
Postby SeaWill » Tue May 14, 2013 1:23 pm
EviewsGarth indicated that i need eviews 7.1 and above to use the add in. I will try to manually code the B-N Decomp. Thx :wink:
trubador
Postby trubador » Tue May 14, 2013 1:26 pm
You can upgrade to version 7.2 freely: http://www.eviews.com/download/download.html
SeaWill
Postby SeaWill » Tue May 14, 2013 7:02 pm
Great! I upgraded and downloaded the add-in. Thanks much!
