Hi, I'm trying to run the following command but I keep getting this message " log1 is not defined or an illegal command"
the command is:
@logl log1
log1=ni*log(1-@LOGIT(-(C(1) + C(2)*log(RUN))))+mi*log(1-(1-@LOGIT(-(C(1)+ C(2)*log(RUN)))))
Re: log1 is not defined or an illegal command
It seems you are trying to run it from the command line. However, you can only use it with LogL object (Object/New Object/LogL), which is EViews' tool to specify and solve maximum likelihood problems. If you only need the log likelihood value, then simply estimate your model via Equation Estimation and retrieve it from the output.
Many thanx 4 ur help. it's work now
hi brake,
can you help me to run this command:
@logl log1
+ C(2)*log(RUN)))))
i am unable to understand ni and mi........
please help me.....
@logl log1
+ C(2)*log(RUN)))))
please help me.....
