Deciles
fhnickel
Deciles
Postby fhnickel » Thu Oct 23, 2008 11:31 am
I have series that contains "na"s and I am looking to find what decile each observation falls into. The series undated. Any help would be appreciated
Re: Deciles
Postby EViews Gareth » Thu Oct 23, 2008 11:52 am
Something along the lines of this should work.
series quantiles for !i=10 to 1 step -1 smpl if x<@quantile(x,!i/10) quantiles = !i next smpl @all
Re: Deciles
Postby EViews Glenn » Thu Oct 23, 2008 3:10 pm
Here's an easier method...use the series "Proc/Generate by Classification". Choose Method = "Quantile Values" and enter "10" as your number of quantiles. We'll create a new series containing the quantiles.
By default we will apply a value map to the resulting output series so that you'll see the ranges for the quantile bins in the default display, but the underlying quantile numbers are there in the series. You can either delete the Valmap specification from the procedure, or turn off the display of the valmap in the resulting series by selecing "Raw data" in the combo in the series toolbar.
