View of the objects
claudio
View of the objects
Postby claudio » Mon Mar 18, 2013 1:12 pm
I wrote the following lines:
for !i=1 to !j
tobjetos(!i+1,1)=!i
tobjetos(!i+1,2)=%lista{!i}
tobjetos(!i+1,3)={%lista{!i}}.@type
tobjetos(!i+1,4)={%lista{!i}}.@description
I have a problem because when open any object on the archive eviews generated, this show the label and not the object (graph, table....)
Re: View of the objects
Postby EViews Gareth » Mon Mar 18, 2013 1:21 pm
That's a little cryptic. Could you provide more information?
claudio
Postby claudio » Mon Mar 18, 2013 1:38 pm
Ok. I wrote large program with 373 object: graphs, tables, svectors, and so on. Finally because i needed to write all description of the object I write the description
on the objects list on svector_lista_objetos:
svector_lista_objetos=@wsplit(@wlookup("*"))
for !i=1 to @rows(svector_lista_objetos)
%lista{!i}=svector_lista_objetos(!i)
svector_tipo_objetos(!i)={%lista{!i}}.@type
for !i=1 to 220
{%lista{!i}}.label(c)
for !i=303 to 343
for !i=1 to !j
tobjetos(!i+1,1)=!i
the problem is that when I open any object on the eviews file generated for the program, the object show the following view the "Object Description", for example:
table: view "table description":
Name:
Display Name:
Last Update:
Description:
Source:
Units:
Remarks:
And if I want to see the object I have select: View>Table. I need please that when I open any object this it open on "object view" and not on "object description".
Postby EViews Gareth » Mon Mar 18, 2013 2:23 pm
Ah, I see.
When you do the label(c) proc from an object it changes the current view to the label view, then when you next open the object by double clicking, it will be on that label view. Change all of your label(c) lines to be:
do {%lista{!i}}.label(c)
The "do" at the front should stop the label view from becoming the default.
claudio
Postby claudio » Mon Mar 18, 2013 2:48 pm
Wonderful Gareth it works very good :D, thanks a lot.
Sorry, but I have other problem. Some objects: all descriptions "sample" object and a few descriptions "graph" objects not appears on the "Details +/-". The code that I used is for example:
{%lista136}.label(d) Gráfico de serie histórica
thanks.
Postby EViews Gareth » Mon Mar 18, 2013 3:50 pm
Sorry, I'm not sure I follow what you mean.
claudio
Postby claudio » Tue Mar 19, 2013 4:02 pm
My problem is that I make two subroutines for graphs and sample and any description for this objects appears on "details +/-".
Postby EViews Gareth » Tue Mar 19, 2013 4:29 pm
Still not sure what you're saying.
claudio
Postby claudio » Tue Mar 19, 2013 4:51 pm
Garreth,
I wrote the "description" to the object "graph" and "sample" with the following sentences:
But the description no appears o I can´t see on the "Details +/-". I think that graphs and sample that I can´t see the descriptions were generated with
two subroutines or command fail on this 2 objtect: graph and sample.
Do you understand me now?
Postby EViews Gareth » Wed Mar 20, 2013 7:42 am
