GARCH forecast for EGARCH model
kiber_master
Postby kiber_master » Tue Mar 12, 2013 12:28 am
Hello!
Could you clarify the formula for GARCH forecast for EGARCH model, when assymetry order = 0? I think, there is some features or even errors in such cases. I've got too small figures in comparison with GARCH on sample period or with the case assymetry = 1.
I use last patch of E7.
Thank you.
Re: GARCH forecast for EGARCH model
Postby EViews Gareth » Tue Mar 12, 2013 7:47 am
I believe the forecast just uses the formula given in the representations view.
kiber_master
Postby kiber_master » Wed Mar 13, 2013 7:27 am
There is no exact formula for GARCH forecast in documentation. I've substituted resids with @SQRT(GARCH) on the forecast period (I suppose, it's correct), and the result differs from EViews output. Although, using this approach I get the same results with EViews output when Assymetry is positive.
Please, check your formula in the program. Is it surely correct?
Postby EViews Gareth » Wed Mar 13, 2013 8:53 am
As I said, the formula used in the representations view is what is used for the forecast. The only question is what happens with pre-sample values. Here's a program that replicates them:
create u 1000 rndseed 1 series y=nrnd series x=nrnd equation eq1.arch(asy=0, egarch, z) y c x eq1.fit yf yse ygarch 'first observation smpl @first @first !pi = 4*@atan(1) !p1 = exp(c(3)) !p2 = !p1*exp(c(4)*@sqrt(2/!pi)) !p3 = !p2*(eq1.@ssr/eq1.@regobs)^c(5) series mygarch = !p3 'other obs. smpl @first+1 @last mygarch = exp(C(3) + C(4)*ABS(RESID(-1)/@SQRT(mygarch (-1))) + C(5)*LOG(mygarch (-1)))
kiber_master
Postby kiber_master » Wed Mar 13, 2013 11:32 pm
I did what you offered: mygarch and ygarch are not equal...
Postby EViews Gareth » Thu Mar 14, 2013 12:02 am
And you're sure you're using the latest version of EViews? I've run that program on three different PCs and got the same results on each.
trubador
Did you use forum search?
Postby trubador » Thu Mar 14, 2013 1:01 am
I get the same results too...
kiber_master
Postby kiber_master » Thu Mar 14, 2013 9:38 pm
But what if I want to forecast GARCH starting with 1001? I have no resids for 1001, so instead of ABS(RESID(-1)/@SQRT(mygarch (-1))) I should use @SQRT(2/4*@atan(1))), am I right?
Postby EViews Gareth » Fri Mar 15, 2013 8:10 am
You can calculate the resid out of sample from the mean equation:
create u 1100 rndseed 1 series y=nrnd series x=nrnd smpl 1 1000 equation eq1.arch(asy=0, egarch, z) y c x smpl @all eq1.fit yf yse ygarch series myresid = y-c(1)-c(2)*x 'first observation smpl @first @first !pi = 4*@atan(1) !p1 = exp(c(3)) !p2 = !p1*exp(c(4)*@sqrt(2/!pi)) !p3 = !p2*(eq1.@ssr/eq1.@regobs)^c(5) series mygarch = !p3 smpl 2 1100 mygarch = exp(C(3) + C(4)*ABS(myRESID(-1)/@SQRT(mygarch (-1))) + C(5)*LOG(mygarch (-1)))
kiber_master
Postby kiber_master » Sun Mar 17, 2013 11:04 pm
Your code is not for this case.
Postby EViews Gareth » Mon Mar 18, 2013 11:16 am
ok, it works the same way:
create u 1100 rndseed 1 series y=nrnd series x=nrnd smpl 1 1000 equation eq1.arch(asy=0, egarch, z) y c x smpl 1001 @last eq1.fit(f=na) yf yse ygarch smpl @all series myresid = y-c(1)-c(2)*x 'first observation smpl @first @first !pi = 4*@atan(1) !p1 = exp(c(3)) !p2 = !p1*exp(c(4)*@sqrt(2/!pi)) !p3 = !p2*(eq1.@ssr/eq1.@regobs)^c(5) series mygarch = !p3 smpl 2 1100 mygarch = exp(C(3) + C(4)*ABS(myRESID(-1)/@SQRT(mygarch (-1))) + C(5)*LOG(mygarch (-1)))
