Hello!
Could you clarify the formula for GARCH forecast for EGARCH model, when assymetry order = 0? I think, there is some features or even errors in such cases. I've got too small figures in comparison with GARCH on sample period or with the case assymetry = 1.
I use last patch of E7.
Thank you.
Re: GARCH forecast for EGARCH model
I believe the forecast just uses the formula given in the representations view.
kiber_master
There is no exact formula for GARCH forecast in documentation. I've substituted resids with @SQRT(GARCH) on the forecast period (I suppose, it's correct), and the result differs from EViews output. Although, using this approach I get the same results with EViews output when Assymetry is positive.
Please, check your formula in the program. Is it surely correct?
As I said, the formula used in the representations view is what is used for the forecast. The only question is what happens with pre-sample values. Here's a program that replicates them:
create u 1000
rndseed 1
series y=nrnd
series x=nrnd
equation eq1.arch(asy=0, egarch, z) y c x
eq1.fit yf yse ygarch
'first observation
smpl @first @first
!pi = 4*@atan(1)
!p1 = exp(c(3))
!p2 = !p1*exp(c(4)*@sqrt(2/!pi))
!p3 = !p2*(eq1.@ssr/eq1.@regobs)^c(5)
series mygarch = !p3
'other obs.
smpl @first+1 @last
mygarch = exp(C(3) + C(4)*ABS(RESID(-1)/@SQRT(mygarch (-1))) + C(5)*LOG(mygarch (-1)))
kiber_master
I did what you offered: mygarch and ygarch are not equal...
And you're sure you're using the latest version of EViews? I've run that program on three different PCs and got the same results on each.
I get the same results too...
kiber_master
But what if I want to forecast GARCH starting with 1001? I have no resids for 1001, so instead of ABS(RESID(-1)/@SQRT(mygarch (-1))) I should use @SQRT(2/4*@atan(1))), am I right?
You can calculate the resid out of sample from the mean equation:
create u 1100
rndseed 1
series y=nrnd
series x=nrnd
smpl 1 1000
smpl @all
series myresid = y-c(1)-c(2)*x
'first observation
smpl @first @first
!pi = 4*@atan(1)
!p1 = exp(c(3))
smpl 2 1100
mygarch = exp(C(3) + C(4)*ABS(myRESID(-1)/@SQRT(mygarch (-1))) + C(5)*LOG(mygarch (-1)))
kiber_master
Your code is not for this case.But what if I want to forecast GARCH starting with 1001? I have no resids for 1001
ok, it works the same way:
create u 1100
rndseed 1
series y=nrnd
series x=nrnd
smpl 1 1000
smpl 1001 @last
eq1.fit(f=na) yf yse ygarch
smpl @all
'first observation
smpl @first @first
!pi = 4*@atan(1)
!p1 = exp(c(3))
smpl 2 1100
