FIGARCH and HYGARCH
mihaela
FIGARCH and HYGARCH
Postby mihaela » Sun May 03, 2009 7:07 am
Hello everyone,
Does anyone of you know if FIGARCH and HYGARCH can be estimated in Eviews? Or if GPH estimator can be used to estimate "d" - the fractional differencing estimator?
Thank you !
trubador
Did you use forum search?
Re: FIGARCH and HYGARCH
Postby trubador » Mon May 04, 2009 12:34 am
Any GARCH family model can be analyzed via Eviews easily. If a specific model cannot be estimated through built-in procedures, then all you have to do is set up a logl object. However, in your case the problem arises from the fact that there is no easy way to take the fractional difference of a series in EViews. Yet, you might still want to check the following link: http://forums.eviews.com/viewtopic.php? ... rier#p1478
mihaela
Postby mihaela » Mon May 04, 2009 12:51 pm
Thanks a lot for your answer!
