Would you mind to give me some advices (step by step) about doing three stages least squares estimation on eviews 6 ? I really need help from some eviews experts here :)
Regards
Tony
Create a system object, enter your equations, and choose 3sls as the estimation method.I plan to use Three stages least squares estimation method for my thesis project, is this method available on Eviews 6 ? As i could not found any three stages least squares command on eviews (sorry i'm newbie). My thesis is about simultaneous equations, as i have 4 equations on these simultaneous equations model.
Regards
Tony
You need to use a coef statement to tell EViews that a0, etc. are coefficients, or use the predefined coefficients, c(1), c(2), c(3)...simultaneous models from literature are:
Gr(Y) = a0 + a1(I/Y) + a2(FDI/Y) + a3GrL +a4Gr(X) + t
FDI/Y = b0 + b1Gr(Y) + b2 (Y/N) + b3Gr(Pw) + t
I/Y = c0 + c1Gr(Y/N) + c2(Y/N) + c3Gr(X) + c4Gr(Kf) + t
Gr(X) = d0 + d1Gr(Y) + d2REER + d3(Y/N)+d4Gr(Yf) + t
a0, b0, c0, d0 are constant number
t is an error terms
how do i transform and enter these equations into eviews correctly ? I've generated all variables and data that i will use into eviews, and give a try to do 3sls. But I got an error message that a0 is not defined. Did I miss something here ?
regards,
Tony
The funny idea here, I've tried with other estimation methods (SURE and OLS), surprisingly i got positif R-square although they are not in a good number (around 20% - 5%)*this is my standard 3sls system's syntax without any adjustment
@inst ipery grl grw reer gryworld
gry = c(1) + c(2)*ipery + c(3)*fdipery + c(4)*grl + c(5)*grx
fdipery = c(6) + c(7)*gry + c(8)*pdbkapita + c(9)*grw
ipery = c(10) + c(11)*grpdbkapita + c(12)*pdbkapita + c(13)*grx + c(14)*grir
grx = c(15) + c(16)*gry + c(17)*reer + c(18)*pdbkapita + c(19)*gryworld
There's nothing necessarily wrong with a negative R-square when using any instrumental variable method, including 3SLS. R-square tells how well you fit the data. That's maximized with OLS. The purpose of 3SLS is to get accurate estimates of the coefficients.I've been working with eviews for days, and using 3sls. Unfortunately, after I have regressed my simultaneous systems, I got some strange results from eviews Output. I found that My all system's R-square was minus :? ?? geez, Did I missed something here ? I've been also tested stationarity each variables as time series models, and entered as first or second difference if some variables had problem with stationarity.
