Models - dummies and trends
ak1234
Postby ak1234 » Fri Mar 01, 2013 12:21 pm
When making a model better can I use both dummy and trend in one model? - as this would then correct for structural break within my data also the trend will allow my model to then have the correct functional form.
I have already created separate models one including a dummy and the other a trend.
But I have to choose only two best long run models and the dummy model on its own does not give me the correct functional form.
Kind regards
A.
Re: Models - dummies and trends
Postby startz » Fri Mar 01, 2013 1:05 pm
Yes.
ak1234
Postby ak1234 » Fri Mar 01, 2013 1:11 pm
thank you.
A.
asiajade747
Postby asiajade747 » Sun Mar 24, 2013 1:17 pm
Hi Guys,
Hoping someone can help me...can you model a dummy variable to be case sensitive or does it have to be done manually? I want to create a dummy to correspond with my data sets increases and decreases.For instance, if the data increases it will be 0 and it will only be 1 if there are decreases year on year. How can I word this command?
Postby startz » Sun Mar 24, 2013 1:32 pm
series dummy = @recode(x>x(-1),0,1)
