Test random Walk
diego45
Test random Walk
Postby diego45 » Fri Dec 14, 2012 3:13 am
Hi everybody
I would like to test that stock market price follow a random walk.
So i did stochastic calculus and i saw that a random walk with a drift could be written like that :
Yt = Y0 + b.dt + o.dWt ...
Where b.dt is the drift
and dWt is wienner or brownien process
So in eviews if i generate x = nrnd
and i regress
DYt = c + x
And that coefficient aren't significant and my residual are white noise is it a random walk or i did a mystake in the procedure ?
thanks
Re: Test random Walk
Postby startz » Fri Dec 14, 2012 8:17 am
You probably want to learn about testing for unit roots.
diego45
Postby diego45 » Fri Dec 14, 2012 8:25 am
no i have done the dick fuhler test and their is a unit root
Sont i cant regress Pt = Pt-1 + ut
due to the presence of this unit root ?
Postby startz » Fri Dec 14, 2012 9:05 am
Your test shows that stock prices have a unit root. That's not quite the same as saying stock prices follow a random walk, but it's close.
Maybe you could tell us more about what you're trying to do.
diego45
Postby diego45 » Sun Dec 23, 2012 9:04 am
Thanks for answer.
I want to test if use technical analysis to forecast price is a good way.
In fact ii i find that their is a random walk i'm sure that technical analysis bring nothing the analyst.
If i found that their is not random walk and if i find that their is serial-correlation between past and day price that i could use technical analysis.
I have found a study that show their is correlation between past and day price but using 1 price per each quarter during 22 years .
Postby startz » Sun Dec 23, 2012 10:02 am
You might define the left hand side variable as the return, dlog(p), and see if you can find varibles that help predict that.
