BVAR not launching spools?
Gloria
Postby Gloria » Sun Dec 02, 2012 1:02 am
I am trying to estimate !i BVAR's, which create !i models for forecasting. When I do this with a VAR solved by LS (option A below) there is no problem. However, when I run the program with the BVAR (option B below), the program stops because too many spools are open. Is there any possibility not to launch the spools or close them within the program?
(A)
'for !i=1 to @dtoo(%finsoft)-@dtoo(%startoos)+1
'SMPL %startestim %endestim
'var var01_!i
'var01_!i.ls 1 6 series1_!i series2_!i series3_!i
'next
(B)
BVAR(m=VAR1_!i) 6 series1_!i series2_!i series_!i
'***FORECAST MODEL
MODEL VAR1_!i 'SOFT MODEL 'only for LS
VAR1_!i.APPEND :VAR01_!i 'only for LS
SMPL %startoos+!i %startoos+!i+11
var1_!i.exclude(actexist=t)
VAR1_!i.SOLVE(s=d)
NEXT
Thanks,
Gloria
Re: BVAR not launching spools?
Postby EViews Gareth » Sun Dec 02, 2012 8:02 am
Modify the BVAR Add-in code so that it doesn't show the spool at the end.
Gloria
Postby Gloria » Mon Dec 03, 2012 4:10 am
Thanks, it worked. I added the comand "close {%sn} at the end of the BVAR.prg. However it opens and closes all the spools, which seems to consume time. Is there another way to tell the program not to open the spools or to run it in a quite modus?
Thanks!
Gloria
Postby EViews Gareth » Mon Dec 03, 2012 7:41 am
Somewhere thee is probably a line saying "show" the spool. Delete that line.
Return to “Add-in Support”
