notepad++ syntax highlingting for EViews
maxchen
Postby maxchen » Sat Nov 24, 2012 5:06 am
syntax highlighting
Line numbering
Highlight the current parenthesis level when editing (useful when nested).
Highlight the current line
Collapse blocks, such as IF, FOR, WHILE or subroutines blocks
the configure file
EViews7.xml.7z
User Defined Language File
(2.47 KiB) Downloaded 1658 times
some screen shot
screen shot
Collapse blocks
Collapse "FOR" block
The screen short are from notepad++ 6.2.2, http://download.tuxfamily.org/notepadpl ... imalist.7z
Or you can find one custom-made by me: http://forums.eviews.com/viewtopic.php?f=5&t=7098
one issue to resolve: see the line 36 or 38, the number is part of the name of variable, but highlight as a number
maxchen
Re: notepad++ syntax highlingting for EViews
Postby maxchen » Fri Jun 28, 2013 2:09 am
there is one annoying bug: identify the " if condition" as "if block"
screenshot
cond if.png (31.42 KiB) Viewed 33632 times
maxchen
Postby maxchen » Sat Jun 29, 2013 6:15 am
The semisolution would be to define closing "Folding in comment" keyword, see
https://sourceforge.net/p/notepad-plus/ ... /56132212/
paues
Postby paues » Tue Aug 06, 2013 12:40 am
One potential solution would be to have "then" be the trigger word for if statements rather than "if".
maxchen
Postby maxchen » Tue Sep 10, 2013 5:29 pm
thanks, great!
maxchen
Postby maxchen » Tue Sep 10, 2013 5:50 pm
update to npp 6.4.5, and for EViews 8.
you can import the language definition file and keep your npp version
EV8-npp.xml.7z
xml configure file only
(2.51 KiB) Downloaded 1073 times
for full working package (npp.6.4.5.bin.minimalist.7z and add some plugins, see http://forums.eviews.com/viewtopic.php?f=5&t=7098)
upzip the attachment, and double click the notepad++.exe will do.
Npp645-EV8.7z
full working green package
(899.46 KiB) Downloaded 1142 times
custom shortcuts
F1: insert time stamp (yyyy-mm-dd hh:mm)
F6: run current file (C:\EViews8\EViews8.exe" in shortcuts.xml should be changed according to your installation of EViews)
F9: save (if change) and run current file
maxchen
Postby maxchen » Sun Oct 27, 2013 5:12 am
minor update:
1 notepad++ to ver 6.5
2 add few keywords for syntax highlingting
if your old version works, you are safe to ignore this update.
Npp65-EV8.7z
(948.32 KiB) Downloaded 1317 times
dagfinnrime
Contact:
Postby dagfinnrime » Thu Jun 18, 2015 1:45 am
thanks for making this available.
I already have NotePad++ installed for other purposes. Which files do I need to take from your "full" setup in order to make it similar?
Solution?
Just copy into my existing notepad++-folder and keep any files with same name?
Dagfinn
maxchen
Postby maxchen » Sat Jun 20, 2015 6:29 pm
Maybe you can try
1 extract http://forums.eviews.com/download/file.php?id=2113 and run the notepad++.exe (close all your running np++ first)
2 export the language definition of EViews as EV.xml
3 exit the notepad++, and launch your original notepate++, import the EViews language
4 copy the RunMeU.dll and NppTimestamp.dll to plugins sub-dir of your original np++
Good luck!
PS: I remember that the background color of np++ is global, you can adjust the color scheme.
maxchen
Postby maxchen » Thu Jul 02, 2015 6:34 am
For EViews 9
import the language definition file, and keep your npp version
EV9-npp.xml.7z
xml configuration file only
(2.6 KiB) Downloaded 1432 times
if your old version works, you are safe to ignore this update (just import the language definition file, and delete your EViews 8 language definition in np++ ).
Npp65-EV9.7z
Notepat++ 6.5 for EViews 9: full working green package
(987.15 KiB) Downloaded 1317 times
Alfred123
Postby Alfred123 » Thu May 27, 2021 8:04 pm
A very nice try!
1. Could you update the notepad++ version for EViews 10 and 11?
2. I am wondering: can I run the EViews code in the notepad directly?
Thanks a lot!
