I get the error message that "you try to raise a negative number to a non-integer power".
Is there a way around this problem? I use Eviews 7.
This is caused in the process of estimating the parameter of risk aversion gamma in (C(t+1)/C(t))^gamma which appears in an euler equation of the consumption asset pricing model.
Non-integer power
martingale
Non-integer power
Re: Non-integer power
Without trying to be flippant, the only way around that problem is to not raise a negative number to a non-integer power.
martingale
One solution is using a loglinear transformation of the Hansen-Jagannathan bound but this would imply the assumption that the correlation of the stochastic discount factor and the volatility of consumption growth is equal to minus 1.
martingale
I realize this is a complicated question, see the discussion at http://math.stackexchange.com/questions ... ve-numbers
