markov switching regime model eviews 7
mengk
Postby mengk » Tue Nov 06, 2012 5:05 pm
Hi everyone,
I am trying to estimate a 2 states Markov Switching Regime model with Eviews 7. Can I use the sspace to estimate this model? Anyone knows how to specify the model's number of states, probability transition matrix in general?
Thank you,
trubador
Did you use forum search?
Re: markov switching regime model eviews 7
Postby trubador » Wed Nov 07, 2012 6:31 am
The following discussion might be of help: http://forums.eviews.com/viewtopic.php?f=4&t=51
mengk
Postby mengk » Wed Nov 07, 2012 8:21 pm
Thank you for pointing that discussion out for me. However, I am still not sure where I should put those code? Should I put them in the sspace or in the command line? I think the discussion is referring to Eviews 6. Does everything applies to Eviews 7?
trubador
Postby trubador » Thu Nov 08, 2012 12:19 am
The formulation requires the use of LogL object, which is the EViews' main feature in building and estimating maximum likelihood models. Currently, state space specification is not feasible in estimating Markov switching models. And yes, you can do all these in EViews 7 as well.
mengk
Postby mengk » Fri Nov 09, 2012 5:06 pm
Thank you for your answer. I am going to work on it now.
