Putting limits on estimated coefficient values
jons
Re: Putting limits on estimated coefficient values
Postby jons » Mon Oct 22, 2012 6:49 am
I’m currently trying to estimate a model on panel data that should look like
y = c(1) + c(2)*x + c(3)*(composite)
with composite being the "best" weighted average of 4 indicators (a, b, d, e). Thus, compo should be of the form
compo = c(4)*a + c(5)*b + c(6)*d +c(7)*e
with 0 < c(4), c(5), c(6), c(7) < 1 and c(4)+c(5)+c(6)+c(7) = 1
I’ve looked at the above but it does not seem to work, results are quite strange… Any idea ?
ele
Postby ele » Thu Nov 07, 2013 10:02 am
Hallo,
I have tried to use the logistic transformation, i.e. (H-L)*@logit(c(1)) + L, to estimate a two-sided restricted parameter within a State Space framework, but I always get the same error message "WARNING: Singular covariance - coefficients are not unique". More specifically
{%model}_ss.add @STATE sv1 = sv1(-1)+ (0.4*@logit({%theta1})+0.3)*d(ltu)+[VAR = {%varstate}]
where H=0.7, L=0.3 and %varstate is equal to an assigned specific value.
The same error message is produced also in case of the one-sided restriction transformation (0.7-exp({%theta1}))*d(ltu). It is not necessarily linked to the weakness of SS models to treat nonlinearities because both the logistic and the exponential transformations can be correctly solved. Hence, I was wondering what is the reason and the solution.
Thanks in advance.
trubador
Did you use forum search?
Postby trubador » Fri Nov 08, 2013 1:15 am
Hard to say without seeing the workfile. But you should consider the possibility that data strongly disagrees with your constraint.
kruupy
Postby kruupy » Wed Aug 27, 2014 4:56 am
HI All,
I would like to put a restriction on one of the coefficients that it is equal to 1.
So Y1 = a + b Y2 + c X2 where b=1.
But what I was wondering is, if I run the regression
Y1-Y2 = a + c X2
Does this regression above impose the restriction that b=1? - Im pretty sure it does, but it would be great if I could get some confirmation.
Cheers,
Andrew.
Postby startz » Wed Aug 27, 2014 6:21 am
You got it right.
ecardamone
Postby ecardamone » Tue Oct 07, 2014 7:39 am
Hi All,
Is it possible to force c(1) = 1 in the following equation, and how could one do it?
Y = c(1)*Y(-1)*(X/X(-1))
Thanks!
Postby EViews Gareth » Tue Oct 07, 2014 7:41 am
If you do that there is nothing left to estimate...
ecardamone
Postby ecardamone » Tue Oct 07, 2014 8:04 am
Right. But if I do the following,
sample large 2014q2 2024q2
smpl large
series X = (@pch(Y)+1)*X(-1)
it performs the calculation for the first time period. How do I get it to perform this calculation for all other periods?
Thank you so much!
Postby startz » Tue Oct 07, 2014 8:13 am
If you are generating the variable Y, rather than running an estimate, try
series Y = c(1)*Y(-1)*(X/X(-1))
taking some care about the sample to avoid NAs from being propagated.
ecardamone
Postby ecardamone » Tue Oct 07, 2014 8:55 am
Oh yes, thank you!
ecardamone
Postby ecardamone » Thu Oct 23, 2014 1:16 pm
Hi, this still doesn't work for some reason. Please help!
I am trying to do something simple. I have quarterly series, call it X, for period 2014q1 to 2018q4. I would like to make series Y by using series X's percent change. I only have one observation on Y, 2014q1.
I set my sample to 2014q1 - 2018q4.
If I try to do this
series y = (x/x(-1))*y(-1), I get only one value for y for 2014q2, the rest is NA. The same happens when I use 'genr' instead of 'series'.
What am I doing wrong?
Thanks so much!
Postby startz » Thu Oct 23, 2014 3:05 pm
You may want to post your workfile.
ecardamone
Postby ecardamone » Fri Oct 24, 2014 5:54 am
Thank you so much! Here is the workfile.
example.wf1
(9.05 KiB) Downloaded 1725 times
Postby startz » Fri Oct 24, 2014 6:10 am
set your sample to
smpl 2014q2 2018q1
ecardamone
Postby ecardamone » Fri Oct 24, 2014 6:17 am
Oh, I can't thank you enough! That worked. Thanks, again.
