mgarch code
hl545
mgarch code
Postby hl545 » Fri Sep 28, 2012 4:31 am
Hi, I am a newer Eviews programming user. I want to estimate a multivariate garch in mean model but my code seems not working. The error message says "overflow". I checked my code several times but it seemd ok. Is it because of the data themselves not fitted or there are some bugs in the code.
atached is the Eviews files.
thanks,
my code bekk.prg
My code
(8.61 KiB) Downloaded 417 times
datauk6ff (dnq).wf1
Data used
(25.37 KiB) Downloaded 271 times
Re: mgarch code
Postby EViews Gareth » Fri Sep 28, 2012 7:09 am
The starting values are bad. EViews is unable to achieve good convergence in the univariate ARCH model used for starting values. You could try using other starting values.
hl545
Re: mgarch code
Postby hl545 » Fri Sep 28, 2012 7:14 am
Thanks very much! For the starting values, I followed the previous examples. Could you possibly suggest me some good starting values or how do I do to make some?
thanks,
