Logl object
XYZXYZ
Logl object
Postby XYZXYZ » Sat Sep 15, 2012 11:53 pm
Im trying to understand how Logl object works and how to use it properly.
So i decided to start with something that Eviews can do automaticaly, like normal GARCH(1,1) model. I estimated both normal GARCH(1,1) with standard estimation settings and Logl that looks just like this:
@LOGL LOGL1
RES = X - C(1)
VAR = C(2)+C(3)*(RES(-1)^2)+C(4)*VAR(-1)
LOGL1 = -(1/2)*log(VAR)-(1/2)*log(2*3.1416926)-((RES)^2)/VAR
I added first VAR number by hand. And it equals unconditional variance.
It seems that these two prosidures give me different results. C(2) and C(3) are 2 times greater then in a stardard procidure. Please help me, how can I get exactly the same result in Logl? Thank you!
XYZXYZ
Re: Logl object
Postby XYZXYZ » Sun Sep 16, 2012 3:00 am
And one more question.
Does Logl object support loglikelihood with @iff function in it? Im trying to estimate Scewed-t distribution GARCH(1,1) with the following code:
@Logl skewt
RES = x - C(1)
VAR = C(2) + C(3)*((RES(-1))^2) + C(4)*VAR(-1)
ce = (@gamma((C(6)+1)/2))/((@sqrt(3.1416926*(C(6)-2)))*(@gamma(C(6)/2)))
lnce = @gammalog((C(6)+1)/2) - log(3.1415926*(C(6)-2))/2 - @gammalog(C(6)/2)
a = 4*C(5)*ce*(C(6)-2)/(c(6)-1)
b = @sqrt(1 + 3*((C(5))^2) - a^2)
lnb = (1 + 3*((C(5))^2) - a^2)/2
skewt = @iff((RES/@sqrt(VAR)) < -(a/b),lnb + lnce - ((C(6)+1)/2)*(log(1 + (1/(C(6)-2))*(((b*(RES/@sqrt(VAR)) +a)/(1 - C(5)))^2))),lnb + lnce - ((C(6)+1)/2)*(log(1 + (1/(C(6)-2))*(((b*RES +a)/(1 + C(5)))^2))))
As you can see there is an IF function in loglikelihood; Eviews tells me "SKEWT already exists and is of a wrong type". Does @iff cause this problem? Thank you!
Re: Logl object
Postby EViews Glenn » Mon Sep 17, 2012 9:38 am
Does SKEWT exist in the workfile? If so, what type of object is it?
XYZXYZ
Re: Logl object
Postby XYZXYZ » Tue Sep 18, 2012 11:35 pm
Hello Glenn, thanks for reply!
Sorry for that stupid mistake i made. Yes, my Logl was named SKEWT.
I renamed it to SKEWT1 and now things are clear. EViews tells me "@iff is not a Genr or series expression function in SKEWT". Is there something I can do to overcome this problem? Thank you very much!
Re: Logl object
Postby EViews Gareth » Wed Sep 19, 2012 6:50 am
The error message is pretty clear - there is no such function as "@iff". Perhaps you mean "@iif" :wink:
XYZXYZ
Re: Logl object
Postby XYZXYZ » Thu Sep 20, 2012 9:46 am
Oh, thanks a lot! It is so embarrassing to realize all my mistakes were typos.
Now everything works! ...but doesnt converge... even with restrictions and different starting values.
