I'm trying to run ADF uroot tests on a couple of series, but I can't seem to do it even for one series.
My problem is that EViews (version 7.1) doesn't seem to recognise the options I'm specifying at all.
I've tried a few different syntaxes and all I can get is the options window to pop up, but not even with the options I specified ticked.
Here's what I've tried so far...
copper.uroot(adf,trend,lags=0,dif=0,save=temp)
uroot(adf,trend,lags=0,dif=0,save=temp) copper
uroot copper adf trend lags=0 dif=0 save=temp
these all seem to do the same as just running copper.uroot, uroot copper or uroot() copper.
Can anyone tell me how to get this to work??
uroot help
Re: uroot help
Are you running in a program, or from the command line?
Re: uroot help
Ah thanks, it works in the program... why does this happen??
Re: uroot help
Some commands, by default, will bring up the dialog when used from the command line, even if you fully specify their options.
CharlieEVIEWS
Re: uroot help
It seems like with uroot, at least, if you do something like series.uroot(kpss), when it brings up the dialog, the highlighted options should correspond to the options specified (e.g. a kpss test) and not always the default (e.g. ADF, sic selected, max lags=int((12T/100)^1/4)
Re: uroot help
It should. uroot was written quite some time ago, before we made that desirable behavior a priority. At some point the uroot code will be updated to reflect this priority, but at the moment I'm afraid that you'll just have to reset the desired items in the dialog.
