FIML in EViews
JimForest
FIML in EViews
Postby JimForest » Mon Oct 20, 2008 3:27 pm
I was interested in estimating the Fair Macro Model by FIML instead of TSLS. I see that this can be done on a system object but it doesn't appear to be available for a model.
JF
Re: FIML in EViews
Postby EViews Gareth » Mon Oct 20, 2008 5:15 pm
I'm not quite sure I understand what you are asking...
If you have the Fair Model inside a System Object in EViews, then you can estimate it by FIML.
Model Objects cannot be solved by either TSLS or FIML.
Systems can be added to a Model, although I don't think that will do what you want it to.
Your best bet is probably to write the Fair Model inside a System Object and then solve it via FIML.
Return to “Models”
