Export data to existing excel file
johansamuelsson
Contact:
Postby johansamuelsson » Thu May 10, 2012 8:43 am
At our institute (NIER, http://www.konj.se) we are now changing from Aremos to Eviews for calculations of macroeconomic forecasts. Very often we combine heavier computation with excel files that sometimes are a better interface. We have therefore a great need to export data to existing excel files.
As we have noted previously it works fine to load data into existing excel file via VBA. But it requires a relatively good knowledge of VBA coding.
As an alternative, it would be highly desirable to be able to export data directly from a workfile to an existing Excel file via code in Eviews.
Are there any plans for this? Thanks in advance.
Johan
Re: Export data to existing excel file
Postby EViews Gareth » Thu May 10, 2012 8:47 am
It is extremely high up our list.
johansamuelsson
Contact:
Postby johansamuelsson » Thu May 10, 2012 10:31 am
Great!
johansamuelsson
Contact:
Postby johansamuelsson » Wed Sep 05, 2012 10:38 am
What about this issue?
Postby EViews Gareth » Wed Sep 05, 2012 10:57 am
It is still extremely high on our list, and should be implemented in the next version of EViews.
paues
Postby paues » Wed Sep 12, 2012 12:56 am
Do you by "next version" mean EViews 7.3 or EViews 8?
Postby EViews Gareth » Wed Sep 12, 2012 7:03 am
8
victor.alves
Postby victor.alves » Thu Feb 21, 2013 1:43 pm
Is that already possible on Eviews 8 Beta?
Postby EViews Gareth » Thu Feb 21, 2013 1:51 pm
Yes
davey87
Postby davey87 » Mon Mar 11, 2013 6:36 am
Using EViews 8 Beta, I am trying to export data from a workfile to an exisiting Excel file using the following commands:
for %a 0to4 5to9 10to14 15to19 20to24 25to29 30to34 35to39 40to44 45to49 50to54 55to59 60to64 65to69 70to74 75to79 80to84 85to89 90plus wfsave(type=excelxml, mode=update) range="Sheet1!d54" byrow popm.xlsm @keep p{%a}mz1m next
However when I run it I am getting an Error Message that says:
Syntax error: unexpected character '.' in file option settings in "WFSAVE(TYPE=EXCELXML, MODE=UPDATE) RANGE="SHEET1!D54" BYROW POPM.XLSM @KEEP P0TO4MZ1M"
Any idea why this may be happening?
Postby EViews Gareth » Mon Mar 11, 2013 8:21 am
Excel file name goes before the Range= statement.
davey87
Postby davey87 » Mon Mar 11, 2013 9:11 am
Ok thanks. But just so you guys are aware, in the EViews 8 Beta Documentation examples under "wfsave", it is the other way around. The example is provided like this:
wfsave(type=excelxml, mode=update) range=”Sheet2!a1” byrow macro.xlsm @keep gdp unemp
Postby EViews Gareth » Mon Mar 11, 2013 9:16 am
Yep, that's a mistake. I'll make sure it gets fixed.
paues
Postby paues » Fri Apr 05, 2013 3:32 am
Please note that the example provided by davey87 was not updated in the documentation that comes with EViews 8. Is it possible for you to update it in when you release patches?
