Hi there,
I am new to E Views. Currently, I am using EViews 7 to do my research. I was wondering if anyone could help me to create the Multiple Regression as below:
LnFDI = α + β1LnGDP + β2LnGDPG + β3LnGNI + β4LnNR + β5LnEXR + β6LnINF + β7LnEXP +β8LnIMP + β9LnID + β10LnOPEN +ε
All variables are in logarithm form where:
FDI = dependent variable
GDP, GDPG, GNI, natural resource (NR), exchange (EXR), inflation (INF), imports (IMP), infrastructure development (ID) and trade openness of host country (OPEN) = independent variable
Using ordinary least square analysis (OLS). Because variables are calculated in different units such as current US$ (FDI, GDP, GNI, natural resource, exchange rate and imports), percentage (GDP growth, inflation, trade openness) and kWh (infrastructure development), therefore variables will be transferred into logarithm form as a standard process.
Note: Can you please also tell me what I can do with the missing data if I don’t want to delete them from my research because I got some missing data for GNI and ID.
Kind regards,
Sonam
Multiple Regression Help
- data IMF.xlsx
- This attachment includes all data used for my research
- (13.62 KiB) Downloaded 273 times
Re: Multiple Regression Help
You should read through the first three chapters of EViews Illustrated:
http://eviews.com/illustrated/illustrated.html
I have read chapter 1,2,3 and be able to estimate the regression. Unfortunately, the coefficients seem wrong like -17. or 8. (is it true that coefficient must be between +1 and -1) :(
Please advice me how to correct it.
The attached file is my regression result
Thanks a lot
Thanks a lot
- regfull.jpg (139.59 KiB) Viewed 5584 times
You are trying to estimate 10 parameters with 21 observations. That's not likely to work well.
I got 25 observations but then 2 variables got some missing data and it adjusted to 21 observations
You need to look at your data and think about what kind of model makes sense rather than mechanically running a regression.
thanks for your advice. by the way, is it true that correlation coefficient must be between +1 and -1? I have run correlation matrix but it seems fine
Yes, correlation coefficients must be between -1 and +1. But regression coefficients are unrestricted.
