Print screen active window
For posts that don't quite fit into any of the other forums, including posts about these forums themselves.
paues
Postby paues » Wed Aug 29, 2012 1:03 am
In most Windows programs it is possible to take a screenshot of only the active window by pressing Alt+Print Screen on the keyboard. However, in EViews the entire program window is copied (and not only, say, the active workfile). Is there some other way to achieve this? Apart from cropping the copied image manually, that is.
paues
Re: Print screen active window
Postby paues » Wed Aug 29, 2012 1:37 am
It seems that some windows can be copied, while others cannot. It seems that those windows which can be placed outside the boundaries of the main EViews window are perceived as active by Windows. However, those windows that cannot be moved outside the main EViews window are not perceived as active by Windows.
Is there some reason for this behavior? It would be nice if all windows could be moved outside of the EViews window (and also, to connect to my first query, be copied by Alt+Print Screen).
Postby EViews Gareth » Wed Aug 29, 2012 7:01 am
That's just the way that certain programs work in Windows.
Return to “Any Other Business”
