Result interpretation - two stage least squares in Eviews
hanidv
Postby hanidv » Mon Aug 27, 2012 6:20 pm
Hi all,
I am using two stage least square to test the endogenous relationship between 2 variables Y and M
Y = a1 + b1*X + b2*Z + b3*M
M = a2 + b4*Y + b5*Z
Did OLS regression, I got b3 is negative and b4 is negative. However, when I run 2SLS, I got b3 is positive and b4 is still negative.
Anyone know how to interpret this result.
Re: Result interpretation - two stage least squares in Eview
Postby startz » Mon Aug 27, 2012 6:31 pm
Hi all,
How did you do 2SLS? You don't appear to have enough instruments.
hanidv
Postby hanidv » Tue Aug 28, 2012 6:10 am
Hi, thank for reply.
here is my full models:
(1) LEV = a1 + b1*GR + b2*SIZ + b3*PROF + b4*TANG + b5*LIQ + b6*NDTS
(2) LIQ = a2 + c1*GR + c2*SIZ + c3*CFR + c4*LEV
I do OLS with b5 and c4 are negative
With 2SLS, The instruments are
For (1): C GR SIZ PROF TANG NDTS CFR
For (2): C CFR GR SIZ PROF TANG NDTS
And I got b5 negative but c4 is positive.
Postby startz » Tue Aug 28, 2012 6:31 am
Oh, you're obviously fine on the instrument count then.
The standard interpretation would be that running 2sls corrects for bias in OLS, and the 2sls results would be preferred.
hanidv
Postby hanidv » Tue Aug 28, 2012 8:48 am
LEV and LIQ are negatively related in both OLS and also in the first 2SLS, however, for the second 2SLS model, it show a positive relationship. It is contrary with the first one.
Do u think is there any problem inside the model or which model should I believe in?
