Hay,
I am trying to learn programming in eveiws. In doing a CGE modeling excercise, I came across the "illegal name or reserved name" error when I wanted to assign values. Here is the command:
FOR %VR BOT EXR PD PE PM PQ PWE PWM PX QQ QM RPD RPX XD XE XS YH omega
sigma
SERIES %VR
NEXT
BOT=0
PD=1
PWE=1
PWM=1
XD=MSAM(1,2)
The error message says BOT is illegal name or reserved. I am using Eviews 7.
Thanks for your help
Illegal name or reserved name
Regopark98
Re: Illegal name or reserved name
Change the line "SERIES %VR" to "SERIES {%VR}" will do.
Envirogate
Thanks alot working very well now
Envirogate
A similar problem however in obtaining row sums in a matrix. The row total suppossed to be 100 while the command I am using is giving me a crazy number. Any help would be appreciated. Here is the command.
!NRWS=@ROWS(MSAM)
FOR !R=1 TO (!NRWS-1)
ROWVECTOR RV{!R}=@ROWEXTRACT(MSAM, !R)
VTOT(!R)=@SUM(RV{!R})
DELETE RV{!R}
NEXT
!NRWS=@ROWS(MSAM)
DELETE RV{!R}
NEXT
Seems to work for me:
create u 10
matrix(10,3) msam
rnd(msam)
vector(10) vtot
!NRWS=@ROWS(MSAM)
DELETE RV{!R}
NEXT
Envirogate
Thanks it also work for me but the problem is the row sum is not correct. What I get is 3900 while the sum is 100.
Works for me.
Envirogate
Thanks I opened a new program file and a copy paste made it possible. But for curisity when I run the program multiple times the row sum multiplies itself.
Ignoring from the pedagogical value of the exercise, wouldn't the following be easier?
Not sure about the increasing value of VTOT on repeats. Doesn't seem to do it for me.
vector vtot = @csum(@transpose(msam))
I am using version 8, and Iam using the same model code. but its not workin for me.. any help on this?Change the line "SERIES %VR" to "SERIES {%VR}" will do.
thanks
You need to change what you're doing wrong to be something that is right.
