On my computer, using Copy, then Paste repeatedly, each Ctrl-V takes a lot of time (several seconds) even for small strings (like three characters long).
Maybe it comes from my computer, but this happens only with Eviews.
Jean Louis Brillet.
Ctrl-C
Re: Ctrl-C
Where are you doing the pasting?
Re: Ctrl-C
Any time I edit a .prg file. But it seems to happen essentailly with large prgs. Like 20k+. And if I repeat the Ctrl-V quickly.
Jean Louis B.
Jean Louis B.
Re: Ctrl-C
That is probably caused by the syntax colouring (it takes a while for it to catch up if you paste into a large program). If you turn off syntax colouring you should find it speeds it up.
Re: Ctrl-C
There was also an update patch posted some time ago which sped up pasting. If you havent already updated your copy, please do so.
