i am trying to save multiplus forecast results from var in to a group but i do not know how. I am doing the following steps:
1 - estimate var models
2 - make model
3 - solve the model
the next step would be to salve the forecasts results in to a group called "forecast". The problem is to change the name of the series forecast of each var in order to save all the resoults. The way i am doing, its overwright the results of each var.
By now, i got the following code:
VAR VAR_2_AIC.LS 1 4 D_IPCA_LIVRE D_IPCA_ADM D_TCR_IPCA SELIC_REAL D_PROD_IND D_M1 'set var model
VAR_2_AIC.MAKEMODEL(MOD2_AIC) 'make the model from var
smpl {%data_inicio_proj} {%data_fim} 'set forecast period
SOLVE MOD2_AIC 'make the forecast
VAR VAR_2_SIC.LS 1 1 D_IPCA_LIVRE D_IPCA_ADM D_TCR_IPCA SELIC_REAL D_PROD_IND D_M1
VAR_2_AIC.MAKEMODEL(MOD2_SIC)
smpl {%data_inicio_proj} {%data_fim} 'determina o período para a projeção
SOLVE MOD2_SIC
group forecast
forecast.add d_ipca_adm_0
forecast.add d_ipca_livre_0
Tks.
Saving forecast from var
Re: Saving forecast from var
Because the endogenous variables are the same in each model, each solve of the models will overwrite the forecast series. The easiest thing to do is to create new series equal to the forecast series between each solve.
series forc1 = d_ipca_adm_0
series forc2 = d_ipca_livre_0
series forc3 = d_ipca_adm_0
group forecast forc1 forc2 forc3
SOLVE MOD2_SIC
