simple OLS regression- F-statistic is not reported
Re: simple OLS regression- F-statistic is not reported
Gobble, just a reminder that--to someone outside your project--it appears you're running your regression backwards.
devi.lupita
i also have the same problem. the F-statistic is not reported.I can verify that the bug has not been fixed.
So that you can get on about your work, I have done the following.I've posted the results for you, but I'm 99% certain that you wantCode: Select all
series rlag=r(-1) ls rlag c rinstead.Code: Select all
ls r c rlag
could you please elaborate the steps to add those code?
thanks in advance
First thing, update your copy of EViews.
devi.lupita
I used EViews 6.0 at the first, and I didn't find the F-statistic and probabilty on my output.First thing, update your copy of EViews.
Then I upgrade the version to 7.1 but there was no changed.
is there any other way to fix this?
Apply the free update get to version 7.2 and see if that helps.I used EViews 6.0 at the first, and I didn't find the F-statistic and probabilty on my output.First thing, update your copy of EViews.
devi.lupita
I've upgraded the version to 7.2, but it still didn't help.Apply the free update get to version 7.2 and see if that helps.I used EViews 6.0 at the first, and I didn't find the F-statistic and probabilty on my output.First thing, update your copy of EViews.
This is the data pooled i used
This is the steps of the estimation
and this is the output
Maybe you could find my wrong when I do the steps of the estimation.
I really need the value of F-statistic and probability using very basic OLS regression method.
The problem is probably that you don't have a constant term.
devi.lupita
I see. But, the constant term comes automatically after every estimation, doesn't it?
So, what's wrong?
I estimated my data using another method (both fix effect and random effect) and I got the constant term, F-statistic and probability as well.
What should I do to get those values in OLS method?
So, what's wrong?
No, EViews does not include a constant term automatically. You need to include "C" as a variable if you want a constant term.
devi.lupita
How can I make "C" as a variable?
where should I put the "C" to make it as a variable since there's no data for variable "C"?
You may see my steps above.
Just put C in with the list of common coefficients. You don't have to define it because "C" is predefined.
devi.lupita
It works! thank you soooo much for your help.
devi.lupita
One question more, I automatically got the constant term, F-statistic and probability when I estimated my data using another method without put "C" in with the list of common coefficients.Just put C in with the list of common coefficients. You don't have to define it because "C" is predefined.
Could you please explain me about this?
You would need to show exactly what you did.
devi.lupita
I estimated my data with those method (Fixed and Random Effect).
I didn't put "C" in the list of common coefficients, but I got the constant term, F-statistic and probability on my output automatically.
These are the step and output of fixed effect data estimation
These are the step and output of random effect data estimation
