simple OLS regression- F-statistic is not reported
gobbble
Postby gobbble » Wed Aug 01, 2012 1:00 pm
I have the problem that at the very basic OLS regression of a return variable against its first lag no F-statistic is reported! What can be the problem and how can I get the f statistic and probability. The regression looks like "r(-1) c r"
edit: I am using eviews 7
Postby startz » Wed Aug 01, 2012 2:23 pm
That's a regression of lagged r on r, not the other way around.
Past that you may want to post your output.
gobbble
Re: simple OLS regression- F-statistic is not reported
Postby gobbble » Thu Aug 02, 2012 1:01 am
here it comes. Regards
regression on r.jpg (54.24 KiB) Viewed 15194 times
Postby startz » Thu Aug 02, 2012 6:09 am
Something's really, really wrong as you also have a negative R-sqr. I think you've hit a bug. The EViews folks are going to want to know the version and build date of your copy of EViews (Help/About).
gobbble
Postby gobbble » Thu Aug 02, 2012 9:15 am
thanks. I have eviews 7 standard edition Jan 7 2010 build.
By the way, when I regress the other way around, everything turns out fine...
Postby startz » Thu Aug 02, 2012 9:17 am
You should probably push the update button, since your copy is more than two years out of date. If convenient, it would also be helpful if you posted your EViews workfile.
Postby EViews Gareth » Thu Aug 02, 2012 9:19 am
You should update to the latest version, by running the upgrade installer.
http://eviews.com/download/download.html
Postby EViews Glenn » Thu Aug 02, 2012 9:47 am
I was waiting to see the output before I nosed in on this one, but so far as I can see, the F-statistic is always reported in this setting in the shipping version of EViews.
gobbble
Postby gobbble » Thu Aug 02, 2012 12:20 pm
unfortunately I cannot uldate it, asI use the license of my university. I have admin rights to update it...
Postby EViews Gareth » Thu Aug 02, 2012 12:21 pm
Post your workfile, so we can check it has been fixed in the latest version for you.
gobbble
Postby gobbble » Fri Aug 03, 2012 3:29 am
here is the workfile
return on art whole.wf1
(19.25 KiB) Downloaded 479 times
Postby startz » Fri Aug 03, 2012 7:07 am
I can verify that the bug has not been fixed.
So that you can get on about your work, I have done the following.
series rlag=r(-1) ls rlag c r
I've posted the results for you, but I'm 99% certain that you want
ls r c rlag
instead.
Postby EViews Glenn » Fri Aug 03, 2012 9:55 am
Thanks for posting the workfile gobble. That helps a great deal.
That's a good suggestion startz and the one that I've used to verify the issue.
I'll have a fix posted shortly.
[edit: it's up]
Postby EViews Glenn » Fri Aug 03, 2012 12:02 pm
A fix has been put into the main code base. Please look for the update shortly. I'll try to get them to get it out today.
gobbble
Postby gobbble » Sat Aug 04, 2012 1:41 am
thanks for your help!
