Really , can i please know the values ? and if possible could you attach the work file .
Thank you in advance.
Stata and Eviews different results
Re: Stata and Eviews different results
Null Hypothesis: EXPORTS_OF_GOODS_AND_SER has a unit root
Exogenous: Constant
Lag Length: 0 (Automatic - based on SIC, maxlag=7)
t-Statistic Prob.*
Augmented Dickey-Fuller test statistic -0.657720 0.8429
Test critical values: 1% level -3.661661
5% level -2.960411
10% level -2.619160
*MacKinnon (1996) one-sided p-values.
Augmented Dickey-Fuller Test Equation
Dependent Variable: D(EXPORTS_OF_GOODS_AND_SER)
Method: Least Squares
Date: 07/30/12 Time: 08:24
Sample (adjusted): 2 32
Included observations: 31 after adjustments
EXPORTS_OF_GOODS_AND_SER(-1) -0.027429 0.041703 -0.657720 0.5159
C 7.40E+08 4.71E+08 1.571120 0.1270
R-squared 0.014698 Mean dependent var 4.65E+08
Adjusted R-squared -0.019278 S.D. dependent var 1.20E+09
S.E. of regression 1.21E+09 Akaike info criterion 44.73044
Sum squared resid 4.26E+19 Schwarz criterion 44.82295
Log likelihood -691.3218 Hannan-Quinn criter. 44.76060
F-statistic 0.432596 Durbin-Watson stat 1.986682
Prob(F-statistic) 0.515905
Exogenous: Constant
t-Statistic Prob.*
5% level -2.960411
10% level -2.619160
Great ! that is the result when you do using Eveiws , but the result in stata please ?
dfuller exports_of_goods_and_ser
Dickey-Fuller test for unit root Number of obs = 31
---------- Interpolated Dickey-Fuller ---------
Test 1% Critical 5% Critical 10% Critical
Statistic Value Value Value
Z(t) -0.658 -3.709 -2.983 -2.623
MacKinnon approximate p-value for Z(t) = 0.8574
. dfuller exports_of_goods_and_ser
Wow ! unbelievable , i get different answer while using stata. The command for stata is : Dfuller (variable) - this is what you did right ? Also let me know if you have converted the data from string to long and to float in stata 11.1 - Confirm me this please.
I dropped your Excel file into EVIews and exported the Stata file from EViews. My guess, though I really don't know, is that you made an error in Stata somewhere. It doesn't sound like Stata and EViews disagree.
Still not sure why my results are different when doing the test in stata alone . Thank you very much for the help. Bless you !
