Programming/ Setting Value for Coefficients
canboardrp
Postby canboardrp » Thu Jul 26, 2012 12:58 pm
I'm wondering if there's a way to set/force a coefficient to take on a specific value.
For example, is there way to set the following when I'm programming so that c(2) = -0.15 and that carries into the estimation and the output?
LOG(TSEC ) = C(1) + C(2)*LOG(DIESEL)+C(3)*(POP) + C(4)*LOG(gdp)+ C(5)*DUMMYQ1 + C(6)*DUMMYQ2 +C(7)*DUMMYQ3
EViews Esther
Re: Programming/ Setting Value for Coefficients
Postby EViews Esther » Thu Jul 26, 2012 1:05 pm
Can you be more specific? When you fix c(2)=-0.15, the term "c(1)-0.15*LOG(DIESEL)" will be the intercept in the equation.
Postby EViews Glenn » Thu Jul 26, 2012 2:39 pm
To followup. The only way is to remove C(2) from the estimation. EViews doesn't allow you to have coefficients that aren't estimated.
