Deperately seeking rolling forecast help
EoinM
Postby EoinM » Fri Jul 20, 2012 11:01 am
I am having some trouble with rolling volatility forecasts.
I have a file containing 5053 observations and I have estimated volatility using the EGARCH module included in eviews over the first half of the data. Then I am trying to use that equation (eq01) to do rolling forecasts of varying lengths to the end of the data. I have attached the code I have peaced together from the forum and the sample files. I runs but the output does not appear correct. If anyone can help I would be very grateful
E
ukrangebase.WF1
(332.2 KiB) Downloaded 604 times
workingprognew.prg
(724 Bytes) Downloaded 1116 times
EViews Esther
Re: Deperately seeking rolling forecast help
Postby EViews Esther » Fri Jul 20, 2012 3:09 pm
From your program, I could not clearly figure out what you are trying to do. Can you answer the following questions: do you want to obtain 1-period-ahead forecast values? Or, do you want to store coefficient estimates? The following code will do 1-period ahead forecast and save the forecast values in the series fcast and store the coefficient estimates in coefmat.
' set window size !window = 2500 ' get size of workfile !length = @obsrange ' declare equation for estimation equation eq01 %cmnd = _this.@command 'EDIT: get the equation specification ' set step size !step = 5 'calculate number of rolls !nrolls = @floor((!length-!window)/!step) 'matrix to store coefficient estimates matrix(6,!nrolls) coefmat 'where the number of coefficients is 6. series fcast 'series to store forecast estimates series fcastse series fcastvar %start = "@first" %end = "@last" !j = 0 ' move sample !step obs at a time for !i = 1 to !length-!window+1-!step step !step !j = !j +1 %first = @otod(@dtoo(%start)+!i-1) %last = @otod(@dtoo(%start)+!i+!window-2) smpl {%first} {%last} 'estimate equation - note I'm error catching here, any errors mean we'll keep going. !maxerr = @maxerrcount setmaxerrs !maxerr+1 _this.{%cmnd} 'estimate equation if @lasterrnum>0 then clearerrs else colplace(coefmat,eq01.@coefs,!j) 'store coefficients ' 1-period-ahead forecast %pers = @otod(@dtoo(%start)+!i+!window-1) 'start point %pere = @otod(@dtoo(%start)+!i+!window-1) 'end point if @dtoo(%end) < @dtoo(%pere) then 'check whether the forecast end point is greater than the workfile end point exitloop endif ' set smpl for forecasting period smpl {%pers} {%pere} eq01.forecast(f=na) audf1 aud_se aud_var ' store forecasts vars fcast = audf1 fcastse = aud_se fcastvar = aud_var endif next smpl @all
EoinM
Postby EoinM » Sat Jul 21, 2012 3:31 am
Hi Esther,
Thanks a million for your response. I'm trying to get the forecasts and the coefficients.
Also, in the code where it says get the equation specification what should I be writing here?
Eoin
EViews Esther
Postby EViews Esther » Mon Jul 23, 2012 8:05 am
The 4th line lets you specify your equation specification, i.e.,
Please note that when you open your equation, "_this" command will recognize that you are interested in the "equation" object.
EoinM
Postby EoinM » Mon Jul 23, 2012 8:50 am
Thanks Esther,
I am away from my PC with eviews on it at the moment but I will try this within the hour or two
Just to clarify, if I want to specify the equation EQ01, I merely open the equation and this command will run the forecasts based on the equation or do I need to edit the line. Apologies I'm a complete novice at programming and probably asking stupid questions. Again, I greatly appreciate your help
EViews Esther
Postby EViews Esther » Mon Jul 23, 2012 9:15 am
Yes, all you need to do is to open the equation of interest.
EoinM
Postby EoinM » Mon Jul 23, 2012 11:10 am
Esther,
You are a lifesaver. Thank you for all your help!! It's working perfectly
Eoin
Mo'
Postby Mo' » Wed Aug 01, 2012 5:52 am
Hello Esther,
First of all, I want to thank everyone at the Eviews team helping out on this forum.
To the main problem, I am trying to follow the posts and your suggestions in a bid to reproduce Eoin's results but I find that even after opening the eq01 on the workfile before running he code you provided, I get an error message saying :
%CMND is not defined or is an illegal command in ''CMND = _THIS.@COMMAND''
Perhaps, I'm not getting something right.
Also, I'd like to find out if this code can work for other GARCH-type models on Eviews, I am interested especially in TGARCH and GARCH-M models.
Any suggestions would be very much appreciated.
Mo'
EViews Esther
Postby EViews Esther » Wed Aug 01, 2012 8:09 am
Which version of EViews are you using? If you do not have EViews7, the program will not work.
If you have EViews7, then please upload your workfile and program.
Mo'
Postby Mo' » Wed Aug 01, 2012 1:13 pm
Dear Esther,
I have been able to confirm that the code works for Eoin's data using Eviews7. Thank you.
I would like to find out if this code can work the same way(by opening the equation on Eviews7) for a different equation, say a GARCH,TGARCH or GARCH-M?
Regards,
Mo'
EViews Esther
Postby EViews Esther » Wed Aug 01, 2012 1:37 pm
Yes, it will work.
Mo'
Postby Mo' » Wed Aug 01, 2012 2:02 pm
Thank you. I'd get on with it.
Mo'
Postby Mo' » Fri Aug 03, 2012 7:57 pm
Esther,
thanks for your assitance thus far, I have been able to confirm that this code works, as I have compared it with simpler codes and obtained (almost) the same results for the one-period ahead static forecasts(changing to .fit,even though results look the same).
I'm a bit confused as to how to do the 5-period and 10-period ahead forecasts (i.e., forecasts for the 5-day and 10-day horizons as I am using a set of daily data). I am pretty sure it has to do with editing this part of the code(pasted below) but I am not sure about what do do. Please help.
Thanks.
EViews Esther
Postby EViews Esther » Mon Aug 06, 2012 8:11 am
...how to do the 5-period and 10-period ahead forecasts
' 5-period-ahead forecast %pers = @otod(@dtoo(%start)+!i+!window-1) 'start point %pere = @otod(@dtoo(%start)+!i+!window+4) 'end point ' 10-period-ahead forecast %pers = @otod(@dtoo(%start)+!i+!window-1) 'start point %pere = @otod(@dtoo(%start)+!i+!window+9) 'end point
Mo'
Postby Mo' » Tue Aug 07, 2012 8:45 am
Dear Eviews Esther,
I have tried to run a 5_step ahead forecast using the hint you provided and some further adjustments. But each time I try to run the code, I get an error message: Syntax error ''IF @ LAST < THEN''...I really have no idea why this keeps coming up, you've been extremely helpful, thanks in advance.
' set window size !window =800 ' get size of workfile !length = @obsrange ' declare equation for estimation equation eq01 %cmnd = _this.@command 'EDIT: get the equation specification ' set step size !step = 1 'calculate number of rolls !nrolls = @floor((!length-!window)/!step) 'matrix to store coefficient estimates matrix(4,!nrolls) coefmat 'where the number of coefficients is 4. series fcast 'series to store forecast estimates series fcastse ' series fcastvar %start = "@first" %end = "@last" 'variable keeping track of how many rolls we've done !j = 0 ' move sample !step obs at a time for !i = 1 to !length-!window+1-!step step !step !j = !j +1 %first = @otod(@dtoo(%start)+!i-1) %last = @otod(@dtoo(%start)+!i+!window-2) smpl {%first} {%last} 'estimate equation - Error catching , any errors mean we'll keep going. !maxerr = @maxerrcount setmaxerrs !maxerr+1 _this.{%cmnd} 'estimate equation if @lasterrnum>0 then clearerrs else colplace(coefmat,eq01.@coefs,!j) 'store coefficients if {%end} < {%5pere} then 'check whether the forecast end point is greater than the workfile end point return endif ' set smpl for forecasting period smpl {%5pers} {%5pere} eq01.fit(f=na) r_f1 r_se r_var ' store forecasts vars fcast = r_f1 fcastse = r_se fcastvar = r_var endif next smpl @all
