Quandt-Andrews breakpoint test
russellrobins
Postby russellrobins » Tue Jul 10, 2012 1:02 pm
I am using the Quant Andrews test on each equation inside a loop (50 equations total); I am using the ubreak function. I have 3 questions
(1)The program runs fine---except the quand-andrews output table appears each time the ubreak function is executed ---is there anyway to suppress THAT table?
(2) Is there a way I can grab the P-value from the test? (I prefer the Max-F p-value)
(3) Is there a way I can grab the observation number associated with the max-F?
thanks for your help
Russ
Re: Quandt-Andrews breakpoint test
Postby EViews Gareth » Tue Jul 10, 2012 1:19 pm
russellrobins
Postby russellrobins » Wed Jul 11, 2012 7:04 am
your suggested solution worked great---on most things, thanks
I now freeze the table and pull off the p-value (and then delete the table)
However, I still cannot retrieve the observation number associated with the Max-f value ---when I pull the value from row 10 column 1 I get only NA's....am I doing something wrong?
thanks for the suggestion
Russ
Postby EViews Gareth » Wed Jul 11, 2012 7:54 am
rndseed 1 create u 100 series y=nrnd series x=nrnd equation eq1.ls y c x freeze(mytab) eq1.ubreak 15 %text = mytab(10,1) !dotpos = @instr(%text, ".") %obstext = @mid(%text, !dotpos+2) %obstext = @left(%obstext, @length(%obstext)-1) statusline %obstext
russellrobins
Postby russellrobins » Wed Jul 11, 2012 8:14 am
perfect!
thanks
