Panel Estimation
jiya
Panel Estimation
Postby jiya » Tue May 29, 2012 9:38 am
I am estimating a fixed effect model in Eviews 7. When i estimate the model without correcting heterscadasticity I get the result with AIC. But the moment I choose GLS weights : Cross-section Sur and coef covarience method: white cross-section, I dont get AIC/SIC value in the dispaly. Why does this happen?...how can i choose optimal lag length of my interest explanatory variable without thsee criterion?
Re: Panel Estimation
Postby EViews Glenn » Tue May 29, 2012 10:38 am
You need to iterate the weights to convergence.
jiya
Postby jiya » Tue May 29, 2012 10:45 am
How can i do that?...would u kindly elaborate a little more, please.
Postby EViews Glenn » Tue May 29, 2012 12:22 pm
On the options page, there is a setting for iteration.
You want one of the "Iterate weights and coefs" settings.
jiya
Postby jiya » Tue May 29, 2012 9:37 pm
yes there is an option and by default eviews 7 set this iterate coefficients to converge (under "update weights once, then..."). However, there are other options "Iterate weights and coefficients" but I dont know when to choose this option. I hv read the Eviews mannual but I dont find any explanation regarding situations when one can choose a specific options.
Actually, my problem is regarding "optimal lag length" selection and wanna knw hw can i do that in panel regression.
jiya
Postby jiya » Tue May 29, 2012 9:50 pm
when i choose "simultaneous updating" Convergence is achieved after different weight iteration for different lags....next what?
jiya
Postby jiya » Wed May 30, 2012 6:25 am
sir kindly response: when should i choose "simultaneous updating", "sequential updating" , "iterate coef to converge" or "update coefs once".....please give a reply.
Postby EViews Glenn » Wed May 30, 2012 11:41 am
The original question was how to get the IC... Simultaneous or sequential iteration to convergence will tell EViews to produce those statistics.
jiya
Postby jiya » Wed May 30, 2012 11:57 am
yes...they do...thank you so much.
jiya
Postby jiya » Wed May 30, 2012 11:59 am
Although this is not related to my original question still I want kw: when should i choose "simultaneous updating", "sequential updating" , "iterate coef to converge" or "update coefs once".....please give a reply.
Postby EViews Glenn » Wed May 30, 2012 12:20 pm
That's really up to you.
The first two do updating of the weighting matrices, but if you have a nonlinear specification you may get different results. The latter two only compute one weighting matrix iteration and differ in whether the nonlinear specification is iterated to convergence. For a linear specification the first two should be the same and the last two should be the same so the only question is whether you want to iterate the weights to convergence or not.
jiya
Postby jiya » Wed May 30, 2012 12:44 pm
that means one can choose a particular one depending on his/her own choice...that is; one that best fits the model (sine Adj R2 is sensitive to these alternatives)
runawayyy
Postby runawayyy » Mon Feb 11, 2013 7:07 pm
I am using Eviews 6 to estimate a dynamic panel model using unbalanced panel data and GMM/DPD method.
In the result window, I see neither R2 nor Adj.R2 !!
Why is that? and what should I do to know R2 of the model?
Thank you.
ceshiwuhao
Contact:
Postby ceshiwuhao » Wed Mar 06, 2013 1:01 am
runawayyy
Postby runawayyy » Sat Mar 16, 2013 7:55 pm
Can you be more specific?
What exactly should I do?
