I use Eviews 6. Recently, the problem appeared which i can't avoid. The model I created contains variable called "e_base" (it is defined inside the model). Solving the model ends with error "E_base is not defined", though it is defined through one of the identities. The problem is when I try to rename this variable in the text view of the model, Eviews crashes. It is not happening when changing other pieces of code.
Anyone met this problem yet?
Is it possible that it happens because of the name itself? Is it avoidable?
Thank you, in advance.
Eviews crashes after editing the model object
