BPTest (Breusch-Pagan LM test for random effects)
sibelcelik
Re: BPTest (Breusch-Pagan LM test for random effects)
Postby sibelcelik » Sat Jan 01, 2011 11:38 am
Hi, ı need Breuch Pagan LM test code. When I run code above, eviews gives this error.
!N is not defined or is an illegal command in "!N=E1.QNCROSS"
How can ı run this program? Would you please help me?
cdelgado
Postby cdelgado » Fri Apr 20, 2012 9:14 am
Hi guys,
Im trying to run the test on an equation but I get the following error message:
"Matrix or vector given positive dimension in "MATRIX(0,12)_D1T03"
Can you guys help me out please?
Postby EViews Gareth » Fri Apr 20, 2012 9:15 am
Could you post the workfile?
gxg 10
Postby gxg 10 » Fri Apr 27, 2012 3:53 am
Hello. i want to instal the LM test ,but i cant. i download the file from the first time page and when i load my eviews file , i still cant select LM test. i cant see it in view residual. please help me.
EViews Esther
Postby EViews Esther » Fri Apr 27, 2012 8:30 am
LM test add-in is not one of residual diagnostics options so that you cannot see the add-in button from the VIEW toolbar.
LM test can be done by running the program.
You will see the available add-in programs on the Add-ins toolbar.
Postby EViews Glenn » Fri Apr 27, 2012 9:25 am
or on the Proc menu under Proc/Add-ins
irene
Postby irene » Sun May 06, 2012 7:51 pm
When running BP test on eq01 in page “China”, EViews will take heavy CPU and memory and then crash.
However, we are able to get the result using the previous version of BPTest Add-in.
Please help to solve the problem.
Thank you for your help.
china200.wf1
(652.78 KiB) Downloaded 1675 times
EViews Esther
Postby EViews Esther » Mon May 07, 2012 8:07 am
The new version of the BPTest is more memory intensive than the previous one, especially in panels with large N. If your computer doesn't have enough memory to run the add-in, you should use the previous version
irene
Postby irene » Mon May 07, 2012 6:28 pm
How many memory should we need?
I ran on the computer which is 64-bit Windows and has 6G memory for 9 hours, but the problem persists.
I still can not get the result.
Thank you!
Postby EViews Gareth » Mon May 07, 2012 6:44 pm
It may be that your data set is too large for any computer to run the add-in.
irene
Postby irene » Mon May 07, 2012 7:14 pm
Would you modify the add-in for large data set?
Thank you.
Postby EViews Gareth » Mon May 07, 2012 7:39 pm
As Esther pointed out, the previous version was less memory intensive...
irene
Postby irene » Mon May 07, 2012 7:58 pm
Would you please release the previous version?
Thank you!
Postby EViews Gareth » Mon May 07, 2012 8:24 pm
I'm confused - didn't you say it worked on the previous version?
suhal
Postby suhal » Fri Jul 20, 2012 1:56 am
i need help for running LM test, i have tried but not successful.
i attached the file.
thanks
Return to “Add-in Support”
