hi,
i seasonally adjusted my series both v5.1 and 7.1 and i got different results. for example v5.1 made my the first two observation positive(+) although in v7.1 they stayed negative(-). is there anybody have this problem.
thanks.
compare seasonal adjustment methots v5.1 and 7.1
Could you explain exactly what you did?
Re: compare seasonal adjustment methots v5.1 and 7.1
i have eviews v5.1 and v7.1. i want to seasonal adjust my series. i import current account deficts series both v5.1 and v7.1... first i seasonally adjusted my current account deficit series with v5.1... v5.1 made my first two observations of current account deficit positive (+) although they are negative.. second i seasonally adjusted my current account deficit series with v7.1 because i want to compare v5.1 and v7.1.... v7.1 did not change my my first two observations sign.
i mean v5.1 and v7.1 give different results.(Tramo-Seats)
thanks.
thanks.
please help...
Again, you're going to have to explain exactly what you did. We can't tell you what is being done differently if you don't tell us what it is that you are doing.
ok.please seasonally adjust my ca series using TRAMA/SEATS with eviews v5.1 and then v7.1. their seasonaly adjusment results different.
thanks for quick replies.
- ca.xls
- (21.5 KiB) Downloaded 554 times
Identical.
- tramo.png (236.17 KiB) Viewed 9400 times
