I want to know if there is a way of checking what object/value is actually stored in a program variable?
For eg: if I say
%lastdate = "2011m06" or
!val=@datediff(@dateval("%lastdate","yyyy[m]MM"),@dateval("%startdate","yyyy[m]MM"),"mm")
how can I check what values are stored in %lastdate and !val? and the type? As these objects are not displayed in the workfile.
Any help is appreciated.
Thanks!
Programme variables
Re: Programme variables
You can either assign them to an object in the workfile (a scalar, a string or a table), or use the sendstatus command to see them in the status bar.
I see.. Thanks for your prompt reply!
