How to use dummy variables in a time-series regression?
NTUSenna
Postby NTUSenna » Fri Mar 02, 2012 5:56 am
Hi, I'm new to eviews, though I do have some basic econometrics experience.
I'm looking to create a regression to measure the determinants of GDP growth given 5 variables: Investment, Savings, Government Expenditure, Exports and Interest Rates.
I am using annual data from 1960 to 2010 and would like to explore a pre-1997 and post-1997 era for analysing how the variables' influence changed in the two periods. But to improve the reliability of the results rather than split the data set into two regressions (1960-1997 and 1998-2010), I thought I could use dummy variables instead and allow me to keep a longer range of data.
Could I use dummy variables for each variable to control for the two periods i.e 1 = <1997 and 0 > 1997, and if so how?
Many thanks.
Re: How to use dummy variables in a time-series regression?
Postby EViews Gareth » Fri Mar 02, 2012 8:53 am
NTUSenna
Postby NTUSenna » Fri Mar 16, 2012 4:31 am
Thanks for that, I managed to get two dummy variables working for use in regressions to test <1997 (dummy) and >1997 (dummy2) effects. The results I got was that the coefficients etc where just the opposite values for the two dummy variables.
Variable.......................................Coefficient Std. Error t-Statistic Prob.
INVESTMENT*DUMMY.......................-0.311363 0.235947 -1.319632 0.2045
INVESTMENT*DUMMY2..................... 0.311363 0.235947 1.319632 0.2045
This was a result of doing two estimations "gdpgrowth c investment (investment*dummy)" and "gdpgrowth c investment (investment*dummy2)"
Is this supposed to happen because it seems a bit simple results?
Postby startz » Fri Mar 16, 2012 6:51 am
Could you show the commands you used?
NTUSenna
Postby NTUSenna » Sat Mar 17, 2012 5:15 am
So for the dummy variables I created them with:
dummy = @recode (@year <1997, 1, 0)
and
dummy2 = @recode (@year <1997, 0, 1)
Then I ran two estimations to test the original variable and each dummy separately:
gdpgrowth c savings (savings*dummy) investment (investment*dummy) govexp (govexp*dummy) exports (exports*dummy)
and
gdpgrowth c savings (savings*dummy2) investment (investment*dummy2) govexp (govexp*dummy2) exports (exports*dummy2)
Postby startz » Sat Mar 17, 2012 6:25 am
You're getting the right result. The first equation says the coefficient is 3 higher in the first period. The second says it's 3 lower in the second. Both mean the same thing.
NTUSenna
Postby NTUSenna » Mon Mar 26, 2012 2:47 am
Apologies for the late reply, but thank you for the assistance. I think I understand it now!
