Below you can find Temporal disaggregation procedure using Denton, Cholette, Fernandez, BFL, Chow-Lin methods as a subroutine in EViews. Copy and paste the code into your program window to execute. Below I posted also instruction hot to use it. Please feel free to modify and/or improve it.
This procedure was written for Eviews before multi frequency Workfiles were introduced, so all input series are in one frequency. Procedure is working in target frequency, i.e. when you disaggregate series from yearly to quarterly values input series are quarterly. Annual series is technically uniformly disaggregated. Low frequency series is again aggregated (by sum) to original frequency inside the procedure.
Inputs are series (not vectors), before using procedure, you have to define result series (high frequency) and equally distributed low frequency one. In current version I do it using link series. But it can be also done outside Eviews by dividing low frequency number by frequency.
' inclusion of interpolation procedures libraries
include C:\.......\agg_help.prg
include C:\........\ program with disaggregation procedure
' SETTING OF THE TECHNICAL FREQUENCY CONVERSION METHOD FOR ANNUAL SERIES
pageselect A
Oryginal_annuall_series setconvert d
' EXAMPLE OF INTERPOLATION PROCEURE
pageselect Q
link temp_y
temp_y.linkto A::Oryginal_annuall_series
series Oryginal_annuall_series_equally_distributed = temp_y
series Result_series
call disaggregation_subroutine (Oryginal_annuall_series_equally_distributed, Result_series, Indicator, parameters) >>> indicator if needed
delete temp_y Oryginal_annuall_series_equally_distributed
Slawek Dudek
Temporal disaggregation procedures .....
- bfl.prg
- (6.12 KiB) Downloaded 5686 times
- chowlin_fix.prg
- (9.75 KiB) Downloaded 5857 times
- chowlin.prg
- (11.67 KiB) Downloaded 5803 times
part 2: Temporal disaggregation procedures .....
next procedures
- litterman_fix.prg
- (9.7 KiB) Downloaded 5207 times
- litterman.prg
- (11.61 KiB) Downloaded 5268 times
- fernandez.prg
- (9.09 KiB) Downloaded 5355 times
Re: Temporal disaggregation procedures .....
next ones
- agg_help.prg
- (9.28 KiB) Downloaded 7751 times
- cholette_uni.prg
- (8.67 KiB) Downloaded 5019 times
- deanton_uni.prg
- (7.99 KiB) Downloaded 5319 times
hello,sdudek.
In my country, there's no quarterly data about the Ratio of Urban Population.So I need to disaggregate annual data to quarterly data.
I followed your implication and used your commands. But when I ran the program chow-lin procedure written by you, there was nothing happenned. So I need your help sincerely. Thank you. Look forward to your reply.
- fffffff.wf1
- (19.08 KiB) Downloaded 24891 times
- my chowlin.prg
- (11.66 KiB) Downloaded 24424 times
plz post exampole about denton method to convert annual to quarterly data
i have annual data and i need convert to quarterly data.
i need your help plz.
Return to “Program Repository”
