Copy to Aremos bank with labels?
paues
Postby paues » Fri Feb 03, 2012 9:43 am
Is there someway to keep the labels when copying series from a workfile to an aremos bank?
EViews Chris
Re: Copy to Aremos bank with labels?
Postby EViews Chris » Fri Feb 03, 2012 3:04 pm
Can you clarify a bit as to what labels you have in mind?
The 'remarks' attribute should be stored with the object when it is saved into an Aremos databank, and should be fetched back into EViews when the object is read.
The other attributes 'source', 'units', etc. are lost because it's not clear where we should put them inside the Aremos object.
Does this explain things?
Chris
paues
Postby paues » Mon Feb 06, 2012 3:56 am
Thank you! That did indeed help. The label I have in mind is in the series @description.
Btw, Aremos is unable to handle as long series as Eviews, particularly those with higher frequency than monthly. How do I specify what period of e.g. a day-frequency series I want to copy to an Aremos database?
paues
Postby paues » Tue Feb 07, 2012 3:12 am
I am guessing that my question in the last post flew under the radar. So here it comes again:
Aremos is unable to handle as long series as Eviews, especially so for those with higher frequency than monthly. How do I specify what period of e.g. a day-frequency series I want to copy to an Aremos database?
Postby EViews Gareth » Tue Feb 07, 2012 7:23 am
Copy the smaller sample of data to a smaller EViews page first, then copy to Aremos.
