Impulse Responses. Unit Shocks with Structural Decomp.
abossie
Postby abossie » Tue Jan 31, 2012 11:06 am
I feel like I must be missing something obvious. But is it possible to specify impulse response shocks other than 1 S.D. shocks when using a SVAR (structural decomposition) in Eviews 7.0? That is, I want to specify a 1% shock to government spending and trace its effect on several variables (GDP, Inflation, Fed Funds, etc) but my identification scheme is more complex than a Cholesky decomposition.
Anyway, It makes it easier and more straight forward to think about the multiplier when talking about shocks in percentage terms so I was hoping there was an easy way to do this.
Re: Impulse Responses. Unit Shocks with Structural Decomp.
Postby EViews Glenn » Tue Jan 31, 2012 12:33 pm
If I understand your question, unfortunately not using the single radio button.
You can, however, always use the estimated factorization and the user-specified impulse response option to generate the desired impulses from innovations, or you can provide user-specified shocks to the residuals.
abossie
Postby abossie » Tue Jan 31, 2012 1:37 pm
I guess my question was: How do I combine my structural decomposition with a user specified shock to the residual?
*edit* or I guess, is such a thing possible with the graphical interface?
Postby EViews Glenn » Tue Jan 31, 2012 2:41 pm
Do you want the shock to the residual or to the innovation from the structural decomposition?
The residual, you don't really need to do any work as the user-specified shocks are residual shocks. To do a shock to the innovation, you'll need to extract the A and B decomposition matrices from the VAR object, and then feed your innovation shock through them to get residual s hocks.
arthur
Postby arthur » Tue Mar 13, 2012 12:43 am
Hi all,
Gentlemen, I have a question that can seem to be primitive.
What is the difference between static forecast and impulse response?
MaartenG
Postby MaartenG » Sat Oct 26, 2013 3:08 am
Dear EViews Glenn,
Dear EViews Users,
if I get it right, I should follow this sequence in order to induce simultaneous shocks to the innovations in an SVAR model:
- estimate the VAR model
- estimate the structural factorization
- extract the A and B matrices, and calculate (A^-1)*B
- use the calculated elements to induce the shock
Say that I have a VAR with three endogenous variables, of which the latter two have an immediate effect on the first one. My A-matrix hence contains non-zero elements for a11,a12,a13, a22 and a33. My B-matrix is restriced to a diagonal matrix. The resulting matrix M=(A^-1)*B consequently has the same "shape" as my A matrix. To induce a simultaneous shock to the innovations (the latter two variables), I specify a user-specified shock which has the form of a 3x1 matrix, with the following elements:
m12+m13
m22
m33
Can you, or anyone else, confirm that this is the right way to induce a simultaneous shock to the innovations in an SVAR model in EViews?
Thanks!
Maarten
PJ2505
Postby PJ2505 » Thu Nov 07, 2013 3:27 pm
Dear Eviews users/ Gareth/ Glenn,
Following the discussion on this topic, can someone please explain how to do the "use the calculated elements and induce a shock" part (also referred to as "feed your innovation shock through them" part) after I have obtained my VAR residuals, then estimated the structural factorization and obtained my two matrices- A and B and also calculated (A^-1)*B. I have a 4-variable VAR with budget deficit, GDP, Inflation and Interest rates. I want to find the effect of a -1% shock to the structural innovation of the budget deficit on all other variables. (shock to the innovation of only 1 variable) In desperate need of help! My lecturers said they are unable to help since this is not covered in our material for a Bachelors degree.
Thank you,
Elena
